CUE transfer to Sign-on greeting
Hello all,
My customer currently has a 1800 number that is mapped to a DID which calls a CUE script that presents people with Attendant IVR like options. One request they had was to map one of these options * to allow staff to dial this 1800 number while on the road so they can check their voicemail. They would like * to essentially bring them to the Sign-On prompt.
What I did is edited the application called by the 1800 number to have a * option, which does a Call-Redirect to the VM Pilot. Since the call was initiated from the PSTN I thought that Unity would play the Sign-on prompt. This is not the case. Instead I am getting re-order. The application is good because I see the call coming in to CME and matching the VM Pilot Dialpeer. My first thought was that CUE was rejecting the call because the RDNIS field was populated with the application pilot number therefore creating a loop. So I created a translation to rewrite this RDNIS to nothing and I still have the same result.
This is suppose to be easy
Any thoughts
1 ACCEPTED SOLUTION
Re: CUE transfer to Sign-on greeting
If you're using a CUE custom script to do this, it might be easier modifying the script itself. For example, if you have a menu choice that calls the step Call Subflow (voicebrowser.aef), you'll get the voicemail script.
Ryan,
Do you have the following configured ?
voice service voip
allow-connections sip to sip
Yes, I have the following commands on CME.
I have also tried creating a translation rule for the VM Pilot peer to remove RDN-Feilds if it was sent from the 1888 pilot application. This also did not work.
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
dial-peer voice 1888 voip
description ** cue AutoAtten pilot number **
destination-pattern 1888
session protocol sipv2
session target ipv4:192.168.251.2
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 8 voip
description **VM Pilot number**
destination-pattern 6000
codec g711ulaw
no vad
can you also add
dial-peer voice 9 voip
incoming called-number 6000
codec g711ulaw
no vad
Let me know if this helps.
Marschne
Exactly what I was looking for, a simple solution. Calling subflow (voicebrowser.aef) worked like a charm.
194
