CUE VM/AA ports not active.
Recently installed CME & CUE ver 7.1 and by default IVR ports are active.
I couldn't enable auto attendant. When i checked the options in cue it shows VM/AA ports 0 and IVR ports/session 2.
How to enable AA ports or how to increase IVR sesion to max 6 session?
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: CUE VM/AA ports not active.
You don't need the  VMIVR-IVR-SESS, you can delete it and have 2 VM/AA ports.
Then you can buy the additional port licenses, or if entitled, obtain them on the cisco licensing portal.
Have reloaded the module after installing licenses?
Can you include "show license status application" and "show license all". That is done with CUE CLI, not GUI.
Thanks for your reply. Reloaded the module many times but no luck.
Output from CUE FYR...
CUE# sh license status
               License Type Supported
       permanent Non-expiring node locked license
       extension Expiring node locked license
       evaluation Expiring non node locked license
               License Operation Supported
       install   Install license
       clear     Clear license
       annotate   Comment license
       save       Save license
       modify     Modify license priority
       revoke     Revoke license
               Device status
       Device Credential type: IMAGE
       Device Credential Verification: PASS
       Rehost Type: DC_OR_IC
CUE# sh license all
License Store: Primary License Storage
StoreIndex: 0 Feature: VMIVR-IVR-SESS                  Version: 1.0
       License Type: Permanent
       License State: Active, In Use
       License Count: 2 /2
       License Priority: Medium
StoreIndex: 1 Feature: VMIVR-PORT                       Version: 1.0
       License Count: 2 /2
License Store: Evaluation License Storage
StoreIndex: 0 Feature: VMIVR-VM-MBX                     Version: 1.0
       License Type: Evaluation
           Evaluation total period: 8 weeks 4 days
           Evaluation period left: 8 weeks 3 days
           Expiry date: Tue Apr 10 11:19:23 2012
       License Count: 600 /50
       License Priority: Low
       License State: Inactive
           Evaluation period left: 8 weeks 4 days
       License Count: 60 / 0
       License Priority: None
StoreIndex: 2 Feature: VMIVR-IVR-SESS                   Version: 1.0
License Store: Dynamic Evaluation License Storage
StoreIndex: 0 Feature: TCV-USER                         Version: 1.0
       License State: Active, Not in Use, EULA not accepted
       License Count: 600 / 0
All seems good.
Show license status application voicemail ?
When i enable the evaluation license for voicemail, IVR becomes inactive.
Our requirement is to have AA or IVR. At present we dont require voice mail service.
I configured call in number for AA but when i dial from IP phone it gives out busy tone. The reason for that i beleive no license for AA port (but not sure).
CUE#  sh license status application voicemail
voicemail disabled, ivr session quantity (2) is equal to or exceeds available po
rts (2)
rts (2)
Requirement: AA or IVR for max 8 session.
What to be done for the same?
Thanks for the reply. I will try the same...
610
