CUE will not sync time with CME
jon.blomquist
I currently have a UC520 system that CUE time is incorrect on by 5 hours. I have set the time with both Configuration Assistant (the most current version) and from the command line. Last night I also attempted to set the ntp server while logged into CUE and get messages that follows:
UC500-CUE(config)> ntp server 192.168.10.1
WARNING!!! Could not reach 192.168.10.1 using NTP.
WARNING!!! 192.168.10.1 might not have been configured as
WARNING!!! NTP server.
WARNING!!! NTP Server 192.168.10.1 Will be entered in the NTP List
IP address: 192.168.10.1 is the CME side of the UC520
UC500-CUE> conf t
Enter configuration commands, one per line.  End with CNTL/Z.
UC500-CUE(config)> clock timezone
Please identify a location so that time zone rules can be set correctly.
Please select a continent or ocean.
1) Africa            4) Arctic Ocean     7) Australia       10) Pacific Ocean
2) Americas          5) Asia             8) Europe
3) Antarctica        6) Atlantic Ocean   9) Indian Ocean
#? 2
Please select a country.
1) Anguilla                 27) Honduras
2) Antigua & Barbuda        28) Jamaica
3) Argentina                29) Martinique
4) Aruba                    30) Mexico
5) Bahamas                  31) Montserrat
6) Barbados                 32) Netherlands Antilles
7) Belize                   33) Nicaragua
8) Bolivia                  34) Panama
9) Brazil                   35) Paraguay
10) Canada                   36) Peru
11) Cayman Islands           37) Puerto Rico
12) Chile                    38) St Barthelemy
13) Colombia                 39) St Kitts & Nevis
14) Costa Rica               40) St Lucia
15) Cuba                     41) St Martin (French part)
16) Dominica                 42) St Pierre & Miquelon
17) Dominican Republic       43) St Vincent
18) Ecuador                  44) Suriname
19) El Salvador              45) Trinidad & Tobago
20) French Guiana            46) Turks & Caicos Is
21) Greenland                47) United States
22) Grenada                  48) Uruguay
23) Guadeloupe               49) Venezuela
24) Guatemala                50) Virgin Islands (UK)
25) Guyana                   51) Virgin Islands (US)
26) Haiti
#? 47
Please select one of the following time zone regions.
1) Eastern Time
2) Eastern Time - Michigan - most locations
3) Eastern Time - Kentucky - Louisville area
4) Eastern Time - Kentucky - Wayne County
5) Eastern Time - Indiana - most locations
6) Eastern Time - Indiana - Daviess, Dubois, Knox & Martin Counties
7) Eastern Time - Indiana - Starke County
8) Eastern Time - Indiana - Pulaski County
9) Eastern Time - Indiana - Crawford County
10) Eastern Time - Indiana - Switzerland County
11) Central Time
12) Central Time - Indiana - Perry County
13) Eastern Time - Indiana - Pike County
14) Central Time - Michigan - Dickinson, Gogebic, Iron & Menominee Counties
15) Central Time - North Dakota - Oliver County
16) Central Time - North Dakota - Morton County (except Mandan area)
17) Mountain Time
18) Mountain Time - south Idaho & east Oregon
19) Mountain Time - Navajo
20) Mountain Standard Time - Arizona
21) Pacific Time
22) Alaska Time
23) Alaska Time - Alaska panhandle
24) Alaska Time - Alaska panhandle neck
25) Alaska Time - west Alaska
26) Aleutian Islands
27) Hawaii
#? 21
The following information has been given:
        United States
        Pacific Time
Therefore TZ='America/Los_Angeles' will be used.
Is the above information OK?
1) Yes
2) No
#? 1
Local time is now:      Fri Nov 20 03:51:44 PST 2009.
Universal Time is now:  Fri Nov 20 11:51:44 UTC 2009.
Save the change to startup configuration and reload the module for the new timez
one to take effect.
UC500-CUE(config)>
I have rebooted the system and the time is still off. Additionally I was not able to find any other way in documentation to set the time manually in CUE. I don't really know where to go from here. Any help or advise, Thank you,
Jon Blomquist
17 Replies 17
Brandon Buffin
Here are a couple of items to check.
1. Can you ping 192.168.10.1 from the CUE module?
2. Check your timezone in CUE
3. Check for the "ntp master" command in CME
4. There is a bug relating to this issue - CSCsu36827. Check the link below to see if this applies.
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsu36827
Hope this helps.
Brandon
Brandon,
Thank you for your quick reply.
Yes you can ping from CUE.
In my first post that was me setting the Timezone on CUE to Pacific which was also done last night without results.
On CME I set it to have an NTP server prefer and then the NTP master was also set. I then set CUE to use CME as the NTP server and got the error at the beginning of my first post. I left it over night and time is still incorrect.
I will check the Bug you linked and get back to you as soon as possible.
Thanks again,
Jon
Ok, further update, I have read the Bug link and attempted to ping an external ntp server, however from CUE I am only able to ping the CME and no other IP addresses. I think this is the problem. When pinging the Domain controller local (192.168.10.5) I get Destination unreachable reported by 10.1.10.2 the CUE. I also get the same response when pinging the IP address for north-america.pool.ntp.org 1 A 209.167.68.100. Any ideas of how to resolve.
Thanks again.
Jon
Does your CUE module interface have a default gateway. Sounds like a routing problem.
Brandon
Jon
Apologies for using this thread to pass a message to Brandon but the new site is proving slightly problematic.
Brandon
Don't know whether you got my response from invite a friend. Collin Clark also invited me but the e-mails are not working properly so whenever you or Collin try to e-mail me apparently it just goes back to Dan using the supportforums-info@cisco.com.
Just didn't want you to think i was ignoring you in case you didn't get response.
Jon
Jon,
     I received a couple of messages from you yesterday. One appeared as if it was meant for Collin. I don't think you can reply directly to an email message. I think you have to go back to the site and email from there. However, I haven't seen a way to email you. Could be because your email address is hidden and mine is not?
Brandon
Brandon,
I am a newer user to CUE can you give me instructions for checking the default gateway for CUE? I too think the issue is routing related.
Jon
In the CME config, you should see something similar to:
interface Service-Engine0/0
ip unnumbered GigabitEthernet0/0
ip nat inside
ip virtual-reassembly
service-module ip address 1.1.1.2 255.255.255.0
service-module ip default-gateway 1.1.1.1
Brandon
Brandon,
This is from the configuration:
interface Loopback0
ip address 10.1.10.2 255.255.255.252
interface FastEthernet0/0
ip address dhcp client-id FastEthernet0/0
duplex auto
speed auto
interface Integrated-Service-Engine0/0
description cue is initialized with default IMAP group
ip unnumbered Loopback0
service-module ip address 10.1.10.1 255.255.255.252
service-module ip default-gateway 10.1.10.2
Is CUE pointing to 10.1.10.2 for NTP? Is this router NATing traffic out to the internet? If so, and you want CUE to point to an external NTP server, I believe you will need "ip nat inside" on the service engine interface.
Brandon
Brandon,
CUE is not pointing to 10.1.10.2 for NTP and when I set NTP to it I also get the error message saying NTP server could not be contacted. I set ip nat inside on the interface as suggested and this also has not resolved the problem. This router is not routing traffic to the internet there is a PIX locally on the same subnet as the router. It's IP address is 192.168.10.2
I do not have access to any other UC520 systems to compare configuration too. Any other help or ideas for me to check out would great.
Thank you again for you help so far.
Jon
OK. If there is another device connecting to the internet and doing NAT, you will not need the nat statement on the CUE interface. Is the PIX setup to NAT addresses in the 10.1.10.0 subnet to the internet? Is the CME getting NTP (show ntp status)?
Brandon
Brandon,
I don't believe the PIX is setup to nat the 10.1.10.0 address space.
Here is the output from CME ntp status:
ColRheumUC520#sh ntp status
Clock is unsynchronized, stratum 16, no reference clock
nominal freq is 250.0000 Hz, actual freq is 250.0000 Hz, precision is 2**32
reference time is CEB17784.2B1E292A (12:16:04.168 PST Fri Nov 20 2009)
clock offset is 0.0000 msec, root delay is 0.00 msec
root dispersion is 5.13 msec, peer dispersion is 0.00 msec
loopfilter state is 'CTRL' (Normal Controlled Loop), drift is 0.000000000 s/s
system poll interval is 64, last update was 342049 sec ago.
Does not seem to be sync'd. However my question is shouldn't CUE time itself from the CME? Time is correct on CME though manually set at this time.
Thanks again
Jon
Jon,
Can you ping 66.96.30.35 from CME?  Can you re-post the current "sh ntp status" from CUE?
- alan
