CUE without CME
I have 2911 router serves as a SRST GW in a branch. 30 IP phones in the location are connected to a call manager in main branch via H.323.
Need to setup an auto attendant/IVR functionality for the branch. PSTN lines are terminated in the 2911 router. Is it possible to setup CUE in the same 2911 without installing CME?
Everyone's tags (1)
1 ACCEPTED SOLUTION
Hall of Fame Super Red
CUE without CME
Hi Mohamed,
Yes, this would be a supported configuration Can you please review the steps in this excellent doc;
CallManager for Cisco Unity Express Configuration Example
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_configuration_example09186a0080289ef0.shtml
Cheers!
Rob
Please remember to tag your threads and help support "Teachers without Borders"
https://supportforums.cisco.com/community/netpro/idea-center/communityhelpingcommunity
CUE without CME
Hi Mohamed,
Cheers!
Rob
CUE without CME
Hi Rob,
Thanks for the doc. Is it possible to enable GUI for the cue as it makes easy to create custom scripts for AA or IVR.
Cheers...
CUE without CME
Hi Mohamed,
Yes, you will certainly be able to set up the CUE GUI in this config
Cheers!
Rob
CUE without CME
Thanks Rob,
I was able to setup the CUE in a SRST router and also GUI functionality works fine. Instead of JTAPI & CTI ports i use SIP dial peer in SRST router pointing to the CUE and plays the AA and again forwarding to CUCM via voip dial-peer...
Thanks & Regards,
M.Mohamed Raffiudeen...
435
