CUEAC and CIPC
Hi All,
Good day! May we know if possible to use CIPC in Attendant Console?
Here is our scenario: We installed IP phone and Softphone for AC. When there is incoming calls we double click the callsthat appeared on the AC window. We want to answer this on our softphone, however, the calls always goes to IP phone. May we know how to change this?
Hope for your kind assistance on this.
Thank you very much.
John
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
CUEAC and CIPC
The extension you log onto with CUEAC cannot be a shared extension, so if you want to log onto a specific phone you need to ensure the extension only exists on that phone.
HTH,
Chris
CUEAC and CIPC
HTH,
Chris
Re: CUEAC and CIPC
Thanks for the reply. May we know also if you have a documents that the CUEAC not supported shared lines and how to add another user or softphone in AC?
Re: CUEAC and CIPC
Shared Line Restrictions
The following restrictions apply to shared lines:
Do not use shared lines for Cisco Unified Communications Manager Attendant Console pilot points or hunt group members. The phone that acts as the attendant console supports shared lines.
source: http://www.cisco.com/en/US/docs/voice_ip_comm/cucmbe/admin/6_0_1/ccmsys/a03dn.html#wp1100362
please not that this is not unuasual, and has everything to do with CTI control.  Cisco Agent desktop has the same limitation
Please remember to rate useful posts, by clicking on the stars below.
Re: CUEAC and CIPC
Hi All,
May we know how we force the call to the softphone? Because it always go to the Hard phone.
RJ
CUEAC and CIPC
Have you checked if cupc is compatible with cuac?
192
