Community Member
CUEAC server not showing directory
hellow all
i have installed CUEAC 9.1 server client, op can login easily but most of the options in CUEAC client are grayed out ad directory is not showing database also connected as showing in CUEAC, we need directory in cueac client also kindly help me out to solve thi issue.
Have you configured the
Have you configured the features you want??
Have you configured the directory sync??
java
if this helps, please rate
www.cisco.com/go/pdi
Community Member
transfer button is grayed i
transfer button is grayed i dont think so its configurable??
i have confugured queue and its showing in it
yeah i did dir sync but in logs its empty i read blogs i changed the dir rule to telephonenumber equal to * but no luck
Purple
Hi,Can u please  cross-check
Can u please  cross-check under System Configuration ---Directory Source Management, Synchronisation Status as Enabled if using CCMSource or LDAP?
You should get the contacts in Contact Management.
regds,
aman
Community Member
hii am using enterprise
hi
i am using enterprise edition and in it its under resource managment>data synchronization and its enable and connected but still not showing directory
Purple
Hi , try restarting LDAP
Hi , try restarting LDAP plugin in CUEAC.
regds,
aman
Community Member
i did restart plugins and
i did restart plugins and whole server, one thing i tell you i did not create end user and device profile in CUCM for my  users, only using device option to register phones.
should i make end user device profile and extension mobility for it ?
Purple
this means that you do not
this means that you do not have any end users created in CUCM or integrated through AD.
If that is the case, try creating few test end users and check whether they are appearing in contact management in CUEAC.
regds,
aman
Community Member
Still not showing i have
Still not showing i have configured End user also but directory stil not here..:(
Purple
hi , You can refer the bug
hi ,
You can refer the bug for further troubleshooting even though it is for version 8.
https://tools.cisco.com/bugsearch/bug/CSCtj57523
Operator not populating the internal directory
CSCtj57523
regds,
aman
83
