cug outgoing calls barred (53)
I am trying to add another extension to a remote site, I am seeing following error:
PeerAddress 238168, PeerSubAddress , DisconnectCause 35  , DisconnectText cug outgoing calls barred (53)
I have searched & only explanation I could find is "Outgoing calls barred within CUG".
Where will calls be barred ?
Here is outgoing dial-peer & debug output:
dial-peer voice 100 voip
preference 1
destination-pattern 23....
progress_ind setup enable 3
voice-class codec 999
voice-class h323 888
session target ipv4:192.168.250.13
dtmf-relay h245-alphanumeric
fax rate disable
ip qos dscp cs3 signaling
no vad
VG101#
Oct 31 10:43:02.021 EDT: ISDN Se0/0/0:23 Q931: RX <- SETUP pd = 8  callref = 0x0556
        Bearer Capability i = 0x8090A2
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98381
                Exclusive, Channel 1
        Calling Party Number i = 0x2181, '2174917728'
                Plan:ISDN, Type:National
        Called Party Number i = 0xA1, '2172358168'
Oct 31 10:43:02.041 EDT: ISDN Se0/0/0:23 Q931: TX -> CALL_PROC pd = 8  callref = 0x8556
Oct 31 10:43:02.221 EDT: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 2, ConnectionId 77F6F6E030511E1947A0026994BF840, SetupTime 10:43:02.031 EDT Mon Oct 31 2011, PeerAddress 238168, PeerSubAddress , DisconnectCause 35  , DisconnectText cug outgoing calls barred (53), ConnectTime 10:43:02.211 EDT Mon Oct 31 2011, DisconnectTime 10:43:02.211 EDT Mon Oct 31 2011, CallOrigin 1, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
VG101#
VG101#
VG101#
Oct 31 10:43:02.221 EDT: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:10/31/2011 10:43:02.033,cgn:2174917728,cdn:238168,frs:0,fid:26800,fcid:77F6F6E030511E1947A0026994BF840,legID:6926,bguid:77F6F6E0030511E1947A0026994BF840
Oct 31 10:43:02.493 EDT: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 2, ConnectionId 77F6F6E030511E1947A0026994BF840, SetupTime 10:43:02.223 EDT Mon Oct 31 2011, PeerAddress 238168, PeerSubAddress , DisconnectCause 35  , DisconnectText cug outgoing calls barred (53), ConnectTime 10:43:02.493 EDT Mon Oct 31
VG101#
VG101#2011, DisconnectTime 10:43:02.493 EDT Mon Oct 31 2011, CallOrigin 1, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
Oct 31 10:43:02.493 EDT: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:10/31/2011 10:43:02.221,cgn:2174917728,cdn:238168,frs:0,fid:26801,fcid:77F6F6E030511E1947A0026994BF840,legID:6927,bguid:77F6F6E0030511E1947A0026994BF840
Oct 31 10:43:02.501 EDT: ISDN Se0/0/0:23 Q931: TX -> DISCONNECT pd = 8  callref = 0x8556
        Cause i = 0x80B5 - Unknown cause value
Oct 31 10:43:02.565 EDT: ISDN Se0/0/0:23 Q931: RX <- RELEASE pd = 8  callref = 0x0556
        Cause i = 0x82E4 - Invalid information element contents
Oct 31 10:43:02.569 EDT: ISDN Se0/0/0:23 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x8556
Oct 31 10:43:02.569 EDT: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 1, ConnectionId 77F6F6E030511E1947A0026994BF840, SetupTime 10:43:02.029 EDT Mon Oct 31 2011, PeerAddress 2174917728, PeerSubAddress , DisconnectCause 35  , DisconnectText cug outgoing calls barred (53), ConnectTime 10:43:02.569 EDT Mon Oct
VG101#31 2011, DisconnectTime 10:43:02.569 EDT Mon Oct 31 2011, CallOrigin 2, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
Oct 31 10:43:02.569 EDT: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:10/31/2011 10:43:02.029,cgn:2174917728,cdn:2172358168,frs:0,fid:26799,fcid:77F6F6E030511E1947A0026994BF840,legID:6925,bguid:77F6F6E0030511E1947A0026994BF840
Hasrat
1 ACCEPTED SOLUTION
Green
Hasrat,
I was playing with MEET ME in my lab.
You can not dial direct to the MEET ME number until a conference has been started.
Put your MMET ME pattern back into the correct partition.
This partition will need to be seen in the CSS for the incoming gateway.
On one of your IP phones
Handset UP
more
MEET ME
Dial MEETME Number 238168
Phone should now display CONFERENCE
Now dial the MEET ME number from inside on another phone
You should have a 2 way call on the Conference
Now dial from OUTSIDE say a moblie to the External number  2172358168
Alex
Please rate useful posts
Regards, Alex. Please rate useful posts.
Green
Hasrat.
Can you supply a full show run
The called number is
Your dial peer is looking for
If you are droppoing thew 217 in a translation or number expansion then your dial peer is short
Try changing the dial peer to use
destination-pattern 23.....
An additional digit
Alex
Hi Alex,
Thank you for your response, here is voice translation rule, it takes rule 14, as you can see in debug output that it is changed to  238168, all other extwnions are working.
voice translation-rule 1
rule 1 /2172358161/ /102238161/
rule 2 /2172409131/ /238170/
rule 3 /2172409237/ /238171/
rule 4 /2172371522/ /238173/
rule 5 /2172353843/ /238174/
rule 6 /2172379214/ /238177/
rule 7 /2172317786/ /238178/
rule 8 /2172377283/ /238196/
rule 9 /2172377203/ /238195/
rule 10 /2172377284/ /238194/
rule 11 /2172372663/ /238193/
rule 12 /2172317785/ /238192/
rule 13 /2172372469/ /238189/
rule 14 /21723581\(..\)/ /2381\1/
rule 15 /^.*/ /102238161/
Thanks Again,
hasratr
Hi Alex,
Need to mention, this extension is being configured for Conference Meet Me number, in CDR, I am getting
origCause_value of 53, which has an expalanation"Service Operation Violated".
hasrat
Green
Hasrat,
I think that probably explains the call failure.
I doint know which version of CUCM you are running.
From the version 7.0.1 admin book.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/7_0_1/ccmcfg/b03meet.html#wpmkr1065815
Check the security setting on the meet-me number/pattern configuration
Minimum Security Level
Choose the minimum Meet-Me conference security level for this meet-me number or pattern from the drop-down list box.
Choose Authenticated to block participants with nonsecure phones from joining the conference.
Choose Encrypted to block participants with authenticated or nonsecure phones from joining the conference.
Choose Non Secure to allow all participants to join the conference.
Note To invoke this feature, ensure you have a secure conference bridge that is configured and available. Refer to the Cisco Unified Communications Manager Security Guide for more information
Dont think there is much difference between the CUCM versions
Alex
Hi Alex,
Meet me security level is set to non secure, I removed partition still receiving same error.
thanks
hasrat
Green
Hasrat,
Handset UP
more
MEET ME
Alex
Hi Alex,
Thank you for the reply, will try & update.
hasrat
Hi Alex,
It works when conference is setup, thank you for all the help.
hasrat
1227
