CUMA Import CA Response
Hello
I Have CUMA 7.1.3 server and I can try Import CA Response but I get this message error:
Public Keys in the reply and the certificate corresponding to this context do not match.
The Certificate I get of VerySing.
Any Idea for this message.
Regards.
Re: CUMA Import CA Response
Did you change anything when you submitted your request to Verisign? It sounds like some details were changed from the time you created the CSR and then submitted it to Verisign.
In the server? or In the CRS ?
Because I change a Parameter of Call Control Server.
I Try to generate other CRS But When send to verisign Says that this is Created.
Any Way to Resolve this issue.
Ah, then it sounds like your issue is with Verisign. Contact their customer support. They are very helpful and will be able to guide you to a resolution.
I contact the verising support and says that my certificate is correct.
This is the procedure that I use to import CA REsponse and certificate
1.- Create the security context "CUMA_ENTER"
2.- Click On Manage context
3.- in the trusted certificate section click in import then copy & paste the Certificate thet verisign sent me.
-----BEGIN CERTIFICATE-----
MIIFsjCCBJqgAwIBAgIQaSHLEXTo845O9+0M6nWx/jANBgkqhkiG9w0BAQUFADCB
yzELMAkGA1UEBhMCVVMxFzAVBgNVBAoTDlZlcmlTaWduLCBJbmMuMTAwLgYDVQQL
EydGb3IgVGVzdCBQdXJwb3NlcyBPbmx5LiAgTm8gYXNzdXJhbmNlcy4xQjBABgNV
7mKr5pp1jWMztGbI1iPFnH9JRuhWLHr5Ee8miMYyHdMNia+Mu2AiS8zzLNPu+Mce
8cEwoCYP5Zefufajk0lJFTxWoFrZqzHCgMCUVR0kp74JXjn7gV6vZtYnrDp+QVI6
Fx+FW6HZYlkh1vpebA8JEs4LTLGnLKmufleDqwosvQG24/gV+7WM93kAsM1Agqhd
pJGyp0+cYtvD+UKGBC1/7q3U4wHzjA==
-----END CERTIFICATE-----
4.- Click On Import CA replay and copy & paste the code of Intermediate CA Certificates that verising sent me.
MIIFfDCCBGSgAwIBAgIQfju3hLvGVKvSuNZ37MOUqDANBgkqhkiG9w0BAQUFADCB
jDELMAkGA1UEBhMCVVMxFzAVBgNVBAoTDlZlcmlTaWduLCBJbmMuMTAwLgYDVQQL
Bst7q03nK0lZQ4/LE+hufgvx08JdqGd4o4cOvZ6o4MQaMgX/0lwNjC+4PWuKfmrK
mr+RhpSkc72cEEO9//XsYesTMetY3nOuqXAQqiH4lz3KAzqNgohXXcF8W1F3ytTT
q1yWbMkJonRpXbE3U0rWI33ywiS7LAk8n4dR8tNoqqIrP6sDtvolx9/+qTPWGnYy
tV0P/hcJt5CbqE7008EnPQ==
then appear the initials message of discution.
I do wrong the procedure?????
add an image of security context
El mensaje fue editado por: Ivan Mendoza Neri
224
