CUMBE with external unity connection voicemail
Hi All,
we are planning to install CUMBE with unity connection built-in. our customer needs 1000 voicemail but only 300 phones. Business edition with CUC built-in support 500 max. is it possible to have seperate unity connection in seperate server and integrate with CUMBE?
in CUMBE we can add more users with the extension but with different voicemail profile which points to seperate unity connection server.
any suggestion would be very appreciated.
thanks
Alex
Re: CUMBE with external unity connection voicemail
No, you need standalone CUC and CUCM.
CUCMBE does not integrate to any other VM system as it's all in-one-box solution.
If you have done the CUCMBE integration before you should have noticed this.
java
if this helps, please rate
java
www.cisco.com/go/pdi
thanks for the reply,
I've installed 4-5 CUMBE before, but it seems you are able to create seperate voicemail profile with different pilot number and hunt group for voicemail port. I have integrated CUMBE with MS Exchange 2007 as seperate voicemail system before. I am wondering if it's possible to integrate with seperate CUC server.
thanks again
Alex
But that really is a SIP trunk, not SCCP as you integrate CUC.
Simply put
BE is a STANDALONE / SINGLE server solution
So: NO
java
java
186
