06-12-2008 08:20 AM - edited 03-15-2019 11:14 AM
I'm trying to configure a SRST Test from Operations Manager but if fails. The log says:
"target devices: RTR Responder not configured"
Where do I have to configure this RTR responder? Can I configure it from the OM?
Many thanks.
Solved! Go to Solution.
06-12-2008 12:55 PM
The config is done in the SRST router.
SRST router(config)#rtr responder type ?
frame-relay Setup Frame Relay responder
tcpConnect Setup tcpConnect responder
udpEcho Setup udpEcho responder
06-12-2008 12:55 PM
