CUP 8.5 ISO
Hey
Is there are any one have ISO for CUP Ver 8.5 ??
otherwise how I could do to get it ????
thank you for advance.
Any suggestion please.???
THANK YOU FOR THE REPLY I'M
THANK YOU FOR THE REPLY I'M LOOKING FOR THE BOOTABLE ISO
Chris already replied to your
Chris already replied to your question, the only way to get, is via PUT, or reach your SE/AM, no one here can post that for you.
java
if this helps, please rate
www.cisco.com/go/pdi
Hall of Fame Super Silver
Are you looking for new
Are you looking for new install bootable media or upgrade ISO?  If bootable then you need to order it via PUT tool (cisco.com/go/upgrade), if upgrade all ISOs are downloadnable from Cisco's website.
Chris
37
