Community Member
CUP SIP Trunk
Dears,
I have CUP publisher and subscriber.
I have created a sip trunk in our CUCM 8.6.2.  In the section SIP  Informaiton, there is a destination box.  1* is required ip address and  port.  To the right of this is a + button, that adds a new destination  address and port destination.  How is this second one used?  Is it a  round robin, or is it use 1* till 1* fails, then fail over to 2?
When we should use SRV records.I hope in a multinade but for my scenario how i can make a use of this feature.
In Jabber client login server address what ip address i shld put so that incase of failure of any server the jabber client should't  put the redundant server ip address again to login, the failover should occur transparently without any changes on the jabber client
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: CUP SIP Trunk
Well, you did not create an SRV to point to SIP port 5060 of the CUPS servers. Build something like:
CUPS to CUCM
_sip._tcp.CUPS.abc.com       SRV service location:
           priority       = 10
           weight         = 0
           port           = 5060
           svr hostname   = vCUPSub1.abc.com
           priority       = 10
           weight         = 0
           port           = 5060
           svr hostname   = vCUPSPub.abc.com
and then use CUPS.abc.com as the destination of the SIP trunk.
HTH,
Chris
CUP SIP Trunk
DNS SRV for CUPS/IM&P HA has been discussed plenty of times before
https://supportforums.cisco.com/message/4078608#4078608
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Re: CUP SIP Trunk
It is top down, if you want load balancing for IMP use SRV.
Chris
Community Member
Re: CUP SIP Trunk
Hello
I am little bit confuse, I have created below configuaration in the DNS server, now i want to know what is should feed in the destination address of the sip trunk.
What will be my SRV destination address ???. according to the below configuartion.
_cuplogin._tcp.abc.com   SRV service location:
           priority       = 0
           weight         = 0
           port           = 8443
           svr hostname   = cups-sub.abc.com
           priority       = 0
           weight         = 0
           port           = 8443
           svr hostname   = cups-pub. abc.com
CUPS to CUCM
_sip._tcp.CUCM.abc.com       SRV service location:
           priority       = 10
           weight         = 0
           port           = 5060
           svr hostname   = vCUCMPub1.abc.com
           priority       = 10
           weight         = 0
           port           = 5060
           svr hostname   = vCUCMSub1.abc.com
Re: CUP SIP Trunk
CUPS to CUCM
           priority       = 10
           weight         = 0
           port           = 5060
           priority       = 10
           weight         = 0
           port           = 5060
HTH,
Chris
Community Member
CUP SIP Trunk
Hello Chris,
Thank for the reply.
CUPS to CUCM
           priority       = 10
           weight         = 0
           port           = 5060
       svr hostname   = vCUPSub1.abc.com -----> i think this should be replaced by svr hostname = cups-sub.abc.com
           priority       = 10
           weight         = 0
           port           = 5060
       svr hostname   = vCUPSPub.abc.com----->i think hostname should be replaced by  svr hostname = cups-pub.abc.com
  • I hope below is a wrong service configured by me.???
CUPS to CUCM
           priority       = 10
           weight         = 0
           port           = 5060
           priority       = 10
           weight         = 0
           port           = 5060
  • Where  service_cuplogin._tcp.abc.com should be used. ?????
    CUP SIP Trunk
    I did not know you hostnames so I left it up to you.
    _cuplogin is used by Jabber clients as that is the default connection they will use.
    HTH,
    Chris
    Community Member
    Re: CUP SIP Trunk
    Dear Chris,
    Thanks for the reply,
    • CUPS.abc.com will be used SRV destiantion address and no more destination address are abe to add  when SRV is ticked, so the _cuplogin service should be configured where ???
    • when i change the setting on jabber client to default server and try to save, the server address automatically comes to https://loginp.webexconnect.com/cas/auth.do. I tried many times times but no sucess, i think there is a default link in some of the TAB of the presence server. can you route me where i can change this.
    • please answer my point 2 in previous reply, the service which you asked me to configure should be replaced by the below service whic i configure,
    CUP SIP Trunk
    You dont need to add _cuplogin anywhere, that is built into Jabber client and will be used natively unless you change the CUPS destiantion in jabber-config.xml.
    Chris
    Community Member
    Re: CUP SIP Trunk
    Hello chris,
    • when i change the setting on jabber client to default server and try to save, the server address is automatically changes to https://loginp.webexconnect.com/cas/auth.do.  I tried many times times to remove this address by pressing default and then save but no success,How we can remove this value.
    •    I hope the below service is not required as it is configured wrong by me, please confirm.
    CUPS to CUCM
               priority       = 10
               weight         = 0
               port           = 5060
               priority       = 10
               weight         = 0
               port           = 5060
    Community Member
    Re: CUP SIP Trunk
    Hello
    I am using Jabber 9.2 and the issue what i am facing is same according to the link below,
    Does anyone even know where this value is stored so I can remove it?
    https://supportforums.cisco.com/thread/2220735.
    Re: CUP SIP Trunk
    The config is stored in jabber-config.xml file which Jabber downloads from TFTP (CUCM server), if you have not modified the file then it should just point to your _cuplogin srv assuming you select on prem CUPS not webex Connect.
    Can you resolve the srv with nslookup?
    Chris
    Community Member
    CUP SIP Trunk
    Hello chris,
    I was just checking jabber.config.xml file on TFTP of call manager, I did'nt found this file, I was surprise so i went to see in my previous client presence server installation i checked in CUCM i didnt find any jabber-config.xml file but the jabber is working fine for that client.
    I think the jabber-config.xml is uploaded in TFTP only when customized jabber is required please confirm ???
    CUP SIP Trunk
    If it is not there that means the default is used which means reliance on _cuplogin srv or statically entering server during loign.
    Chris
    Community Member
    Re: CUP SIP Trunk
    For previous client there was only one server so i was using the ip address but now in this case i have a redundant server so i am using SRV records and also I am selecting CUPS and not webex,still on pressing the default button  the value comming is  https://loginp.webexconnect.com/cas/auth.do  . It is irritating and i dont know from where to remove the link.
    Community Member
    Re: CUP SIP Trunk
    Thanks Chris,
    If you can put some shade on the query raised in
    386
