Community Member
CUPC logging
This might be a stupid question, but if I enable detailed logging on a CUPC client, where are the resulting logs stored. I can't seem to find them.
Many thanks.
1 REPLY
Community Member
Re: CUPC logging
Ok...If you were getting some users logging into CUPC ok and some not with "unknown login failure" where would you suggest to check?
I've rechecked all the configs of LDAP, SIP etc. All users have capabilities enabled. Just can't see why this is happening. Many thanks.
220
