CUPC not registering wth cucm in softphone mode
I am facing a issue , I have a setup with cucm 7.0 and presence 7.0
In my cupc the sofphone is red other like deskphone etc are green and working fine(show server health )
Softphone is not working and UPC<userid> is unregistered in cucm.
I have checked no dot is there in the userid and tftp is configured propery.
Also i am using cucm internla database
Appreciate yuour help.
Re: CUPC not registering wth cucm in softphone mode
Under show server health, if you click on softphone can your computer resolve the name of the CUCM server?  If that's ok I'd next take a packet capture from the computer running CUPC and filter on SIP to see if the SIP REGISTER makes it to CUCM or not.  You might also want to do a packet capture on the call manager if you are sending the SIP REGISTER to make sure it gets there (https://cisco-support.hosted.jivesoftware.com/docs/DOC-11599)
Silver
Have you assoicated DN on the UPC with the User ?
Below is a url showing simple steps for CUPS/C- may help
http://pushkarbhatkoti.wordpress.com/2009/06/08/cisco-presence-integration-with-ccm-7x-in-20-minutes/
I have verified the DN  it seems to be ok as per the config guide line only.
What i see is that the CUPC is trying to connec to CUCM during softpone registration in Hostname  nand i dont have DNS seems it is not able to resolve IP address and showing as connecting continiously
What need to do in this scenario where DNS is not there.
Appreciate your quicj response
Hi Rupam,
If in case you don't have the DNS server, can you update the hosts file (C:\WINDOWS\system32\drivers\etc\hosts - for XP) in your computer and add the entries for your CUCM and CUPS hostname. This will resolve the hostname of the server to their ip address.
Cheers,
Amrinder - CCIE(Voice) # 27326
I ahve resolved the issue by changing name in the CUPS cluster in the node name setting.
Hope this may be helpful for others.
Rupam
1164
