Community Member
CUPC - Outlook 2003 Add-in - no toolbar.
7.0(1.13056) Unified Personal Communicator on Outlook 2003 SP3.
Missing the Toolbar and it doesn't display the Add-in.
I have removed and reinstalled, and repaired the MSI, but I can't get the toolbar to display within Outlook 2003.
Any ideas?
Silver
Re: CUPC - Outlook 2003 Add-in - no toolbar.
The repair has to be done with the user account and to make that possible, the user must have execute permission on the .msi file. Verify that in Outlook>tools>trustcenter>Add-ins that the "Cisco Unified Personal Communicator for Outlook" is in the "Active Applications" list. If it is in the "Inactive" list, click "go" next to "Manage: COM Add-ins". Add a "check" mark next to the application and click OK.
If the application is in the "active list", you may remove the application from the "Manage: COM Add-ins" page by selecting the application and clicking remove.
Community Member
I had the same issue with Outlook 2003. Initially CUPC worked fine in my outlook 2003, but quit working after outlook in a fail safe mode.
I did not have the trustcenter option, so I dug a little deeper and found that the plugin was disabled. I then enabled it by opening outlook and then going to
help>About Microsoft Office>Disabled Items. Here I saw the item was disabled and was able to enable it here by selecting CUPC and selecting enable.
Thanks, that helped me!
504
