CUPC Voicemail Issue
I have cupc which has unity integration.When I check server health, it tells me voicemail is not connected.
I made sure imap is started on exchange and presence has unity profile.
In CUPC,I do not even get a choice of playing voicemail.
Any ideas on how to fix this?
Red
Re: CUPC Voicemail Issue
Assuming you're using CUPS 7.x, you need to configure mailstore to point to the IMAP server.
Michael
http://htluo.blogspot.com
The above comments are correct. You will need to ensure the CUPS server has VM Servers and Profiles configured and then applied to the user.
here's a doc to assist in the configuration:
http://www.cisco.com/en/US/docs/voice_ip_comm/cups/7_0/english/config_maintenance/administration/guide/b04usrv.pdf
HTH, Please rate if so
Justin
You also have to make sure that under your preferences within the CUPC client for the voice mail server are filled in with username and password.
I have an issue with CUPC where users are able to listen to their voicemail and thus unity integration is working. I checked server health and unity is fine.They do not have the option to place a call to the person who left them a voicemail.I checked that I can leave IM for the caller and call the person directly but callback to voicemail option is not there because the voicemail does not have the callers phone number. I checked the unity active directory and added telephone number for those users but still cannot call back.
I need to understand where does CUPC get this information from. I would assume it is unity active directory. But when I added the phone number and again left a voicemail, I still did not get callback feature. Does sync take time? Any help is appreicated.
694
