Community Member
CUPS 8.6 - Exchange Calender Integration
We have CUPS 8.6 on production, we are planning to integrate CUPC with exchange calender.
We have configured Presence gateway with AD users, AD users are configured Exchange view only, Receive As permissions ect.
Once we configured it, we are getting below error.
Exchange Reachability (pingable) Reachable
Exchange SSL Connection/Certificate Verification
We would like to know what cerificate is missing and what certificate needs to be installed on CUPS.
I have attached the screen shot of gateway configuration and certificate error.
Pls. suggest.
Everyone's tags (1)
2 ACCEPTED SOLUTIONS
Super Bronze
Re: CUPS 8.6 - Exchange Calender Integration
Yes. You need to look at the certificate chain, and ensure all the certs involved are installed. If there are multiple server (i.e. that ISA-02 is not the root CA) then you need the intermediate server certs as well.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Super Bronze
If the two cluster members share the SAME subject name/certificate (e.g. regardess of which one is active, you accces it via CAS-CLUSTER) then you don't need to import both.
Aaron
Super Bronze
From what I can gather CUPS can pull the certificates from your Exchange server if it has a certificate issued directly by a root CA, by lcking the 'accept certificate chain' option. If you have a cert issued by a subordinate CA (which is very common) it doesn't seem to work.
Here's what I do:
1) Browse to OWA, then click the 'padlock' icon in IE or Firefox to view the certificate details.
2) On one of the tabs, you can export that certificate.
3) You can also view the certificate chain, do this and then view each certificate in the chain. Export each one to a file.
4) Once done, go to OS admin, and upload all the certificates (some may already have been imported, but one will  be missing at least). Import them as presence-trust certificates.
Once that's all done you should be able to validate the cert chain in presence admin.
Aaron Harrison
Principal Engineer at Logicalis UK
Please rate helpful posts...
Community Member
Hi Aaron
I have did the same as you mentioned.
through OWA export the certificate and installed on CUPS through OS
Back in Gateway, I have  clicked "Configure" and checked Accept Cerificate Chain.
Exchange SSL Connection/Certificate Verification Missing Certificates
I am getting same error.
Pls. advice.
I have attached the screenshot of OWA and CUPS certificate upload
Message was edited by: RAJESH KUMAR
Super Bronze
In that cert2.jpg I don't see the cert for your the root CA (whatever that server is that ends in ISA-02 in the cert chain display).
You've highlighed something with CUPS in the hostame in the OS cert admin page - that looks like the CUPS  server certiicate, not your root CA.
Aaron
Community Member
I have below certificate(CAS-CLUSTER)installed on CUPS, which is downloaded from OWA.
Under Cups OS certificate,
cup-trust    trust-certs    CAS-CLUSTER.pem    CAS-CLUSTER.der
What you suggest is, we also need to install root certificate form the server ends with ISA-02 ?
Pls. suggest.
Rgds
Rajesh
Super Bronze
Aaron
Community Member
Thanks for the information,
ISA-02 is the root CA.
All the exchange CAS servered certificates are issued by ISA-02.
I will install exchannge CAS-CLUSTER ansd ISA-02 certifcate and update you.
One more question, we have ISA-01 and ISA-02 and CAS-CLUSTER (CAS-01 server, CAS-02 server), we need to install individual server certificate on CUPS ?
Thanks & Rgds
Rajesh
Super Bronze
Aaron
Community Member
Dear Aaron
Thanks a lot. Problem resolved after installing certiface chain (root CA and cas-cluster) on CUPS.
Rgds
Rajesh
Community Member
What if ICMP isn't allowed to the exchange server, does this have to be enabled for this to work?
Joe
995
