Bronze
Custom Edit Dial Soft Key?
Is there a way to do custom soft keys for local calls and long distance calls? What I'm looking for is an easy solution if you have your corporate active directory listed in the directories on the phone and would like to dial the number it finds without having to do an Edit Dial to add a 9 for an outside line for local calls or having to add a 9 1 for long distance calls. I know you could do translation patterns, but there would probably have to be too many of those. Thanks!
Green
Re: Custom Edit Dial Soft Key?
Yes, you should program a service.
Bronze
And you do that how?
Bronze
Anyone? Any ideas or help? Thanks!
154
