Customize 7921
Hi all,
Somebody knows if in 7921 the option mute is can disable?
It is possible in the 7921 phone, change the button left and put the tranfer option
Thanks a lot!
1 REPLY
Re: Customize 7921
Is there a softkey template that you hav e assigned for 7921
I will have to test it on MOnday and then I can give you confirmed answer.
Meanwhile if you want you can play around with softkey template
130
