Customized Softkeys
Is there a way to create a new customized softkey to use on a template? I have set my direct call park retrival code as a line speed dial but would like to have it show as a softkey instead to save some room.
Anyway to do this in CUCM 8.5?
1 REPLY
Hall of Fame Super Silver
Customized Softkeys
Unfortunately, there is no way of adding softkey options outside of what you see under the layout.
HTH,
Chris
141
