04-11-2012 01:53 AM - edited 03-16-2019 10:34 AM
Hi guys,
I am trying to pur our company logo as a background image of Cisco 7945 IP Phones.
I already prepared the .png files ( full view and thumb nail) and list.xml file - attached.
However, when I am trying to copy the file from the tftp server to flash, it does not create the folder Desktops/320x212x12. It says folder does not exist, which i think it is correct. There is no Desktops/320x212x12 folder inside flash. How do I create a folder like that inside flash? or is it ok to not put the files insde that folder and edit the List.xml?
Please help.
Thanks in advance.
04-11-2012 02:02 AM
HI
Are you using following command.
copy tftp flash:Desktops/320x212x12/
regards
Ronak patel
Rate helpful posts.
04-11-2012 02:41 AM
Hi Ronak,
I am using the following command:
CME-FirstTech#copy tftp: flash:
Address or name of remote host [10.0.0.160]?
Source filename [Desktops/320x212x12/]? Desktops/320x212x12/TN-FirstTechnologyLogo.PNG
Destination filename [TN-FirstTechnologyLogo.PNG]? Desktops/320x212x12/TN-FirstTechnologyLogo.PNG
Accessing tftp://10.0.0.160/Desktops/320x212x12/TN-FirstTechnologyLogo.PNG...
Loading Desktops/320x212x12/TN-FirstTechnologyLogo.PNG from 10.0.0.160 (via GigabitEthernet0/0): !
%Error opening flash0:Desktops/320x212x12/TN-FirstTechnologyLogo.PNG (Directory doesn't exist)
04-11-2012 03:00 AM
HI
Use following commnd to create the directory in flash
CME-CUE#mkdir flash:Desktops/320x212x12
Ronak patel
Please rate helpful posts by clicking stars below the answer.
04-18-2012 02:36 AM
Hi Ronak,
That did not work as well.
CME#mkdir flash:Desktops/320x212x12
Create directory filename [/Desktops/320x212x12]?
%Error Creating dir flash0:[/Desktops/320x212x12
05-24-2018 10:50 PM - edited 05-24-2018 11:21 PM
First create the Desktops directory:
mkdir Desktops Create directory filename [/Desktops]? Created dir flash0:/Desktops
and then the images directory:
mkdir Desktops/320x212x12 Create directory filename [/Desktops/320x212x12]? Created dir flash0:/Desktops/320x212x12
Greetings.
