customizing backgroung images for 7970
I want to customize the back ground images for my 7970 Ip phones, However I canot find the list.xml which needs to be editied in my flash...How can I create this file or get it..
Bronze
Re: customizing backgroung images for 7970
Basically, you need to use a text editor to edit the List.xml file. You can use notepad to create and change from txt to xml.
Here is a very good link to walk you through.
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_tech_note09186a008062495a.shtml
Please rate the helpful post.
Ken
ken, thanks. The problem is that the file list.xml is not in my flash..I cant find the file..
Where can I find or download the file
Bronze
Oh.. you can create list.xml by yourself.
for example:
copy the following code to notepad, then save the file. Change the file extension from txt to xml, then copy to flash:
FTP:Desktops/320x212x12/TN-velara.png"
URL="TFTP:Desktops/320x212x12/velara.png"/>
Ken
Hall of Fame Super Red
Hi Okanlawon,
I'm pretty sure that Ken is correct here in that you have to create the list.xml yourself. Have a look at this old thread that has some excellent details;
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Phone%20Services%20for%20End%20Users&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.1dd7478e/3#selected_message
Great answers from Aaron,Steven,Chris and Matt from Cisco!!
Hope this helps!
Rob
Rob, thanks..But my problem is creating the directory Desktops/320x212x12 on the router..
any ideas please?
Silver
I think this is what you are searching for:
rate all helpful posts.
hhi mate, I have that document..My challenge is creating the Desktops/320x212x12 directory on the router..Any ideas please..
Bronze
I get the error too, but here is what you can do:
MainDSP#mkdir flash:Desktops/320x212x12/
Create directory filename [Desktops/320x212x12/]?
%Error Creating dir flash:Desktops/320x212x12/ (Directory doesn't exist)
Create directory filename [Desktops]?
Created dir flash:Desktops
Created dir flash:Desktops/320x212x12/
Basically, you have to create Desktops directory first, then create mkdir flash:Desktops/320x212x12/ again.
Please see above.
Hopefully help.
Ken
Ken, Thanks man..But my challenge is that, the router does not accept the mkdir command..I am thinking its because my flash is formatted with the b flash system format..I am thinking of re formatting using the C flash system format, since this is like the Dos file system..what do you think
Ken, I have been able to create the directories, howevr, I gwt this error when I issue the debug tftp commnad
TFTP: Looking for Desktops/320x212x12/List.xml
TFTP: sending erro 1 Nosuch file
this is the output of my show flash..
0 Jan 11 2007 08:07:22 +00:00 Desktops
81 0 Jan 11 2007 09:08:42 +00:00 Desktops/320x212x12
82 1982 Jan 11 2007 08:19:10 +00:00 Desktops/320x212x12/List.xml
83 3278 Jan 11 2007 08:20:46 +00:00 Desktops/320x212x12/TN-netco.png
84 27328 Jan 11 2007 08:21:26 +00:00 Desktops/320x212x12/netco.png
85 10820 Jan 11 2007 08:22:18 +00:00 Desktops/320x212x12/TN-CampusNight.pn
g
86 131470 Jan 11 2007 08:22:48 +00:00 Desktops/320x212x12/CampusNight.png
87 9657 Jan 11 2007 08:23:34 +00:00 Desktops/320x212x12/TN-CiscoFountain.
png
88 80565 Jan 11 2007 08:24:44 +00:00 Desktops/320x212x12/CiscoFountain.png
89 138278 Jan 11 2007 08:25:04 +00:00 Desktops/320x212x12/Fountain.png
90 7953 Jan 11 2007 08:25:46 +00:00 Desktops/320x212x12/TN-Fountain.png
91 7274 Jan 11 2007 08:26:18 +00:00 Desktops/320x212x12/TN-MorroRock.png
92 109076 Jan 11 2007 08:26:34 +00:00 Desktops/320x212x12/MorroRock.png
and this is my tftp-server config
tftp-server flash:/Desktops/320x212x12/List.xml
tftp-server flash:/Desktops/320x212x12/TN-netco.png
tftp-server flash:/Desktops/320x212x12/netco.png
tftp-server flash:/Desktops/320x212x12/TN-CampusNight.png
tftp-server flash:/Desktops/320x212x12/CampusNight.png
tftp-server flash:/Desktops/320x212x12/TN-CiscoFountain.png
tftp-server flash:/Desktops/320x212x12/CiscoFountain.png
What do you think is wrong
Rob, I have created the directory, However, I keep seeing this error
g
png
182
