Customizing CDR reports from CUCM
Hi all,
A client has sent the following request pertaining to a new deployment. I can show them how to pull CDR records and some of the built in reports but is there a product out there which will them to create customized reports directly from the CDR/CAR databases? Thanks in advance for any assistnace.
"For some time now I have been trying to get a CDR record out of the system. The record needs to include Extension, Name, Time, Duration, Digits dialled, and when multiple records are found they should be grouped by Extension."
Green
Re: Customizing CDR reports from CUCM
No option inside CDR
They need to go for a 3rd party billing server
which provide those options
I know of a product that can do that for you. You can contact me for more details.
Reagards..
Hi Walid,
Can you share your input specific to this and email the information at manishankarp78@gmail.com
Is it possible to customize CDR Reports using Crystal Reports?  My customer has CUCM v7.1.5 (Informix Database) and wants to customize CDR reports.
Thanks.
Eduardo.
eduardo.ojeda@unifiednetworks.com.mx
You should use a 3rd party call logging product for this.
Certified products can be found on the Cisco Developer site http://developer.cisco.com/web/partner/search?text=call logging&technologyIds=a0G40000000xlnlEAA&certified=Yes&onCiscoPriceList=All&portfolioPartner=All
Depending on your UCM size we have two products that auto configure, based on your UCM configuration to load all your users, handsets, gateways, UDP's etc. Installs are less than five minutes!
TIM Plus for up to 400 users and TIM Enterprise which has unlimited users, both have AXL integration and free unlimited display boards, unlimited web users. For more information or to arrange a free trial go to www.tri-line.com/cisco
TIM Enterprise overview video:
AXL integration video:
Let me know if you need any further information.
873
