CUVA error
Dear NetPro gurus,
Has anyone see this before??
16:16:36 2 CNetAdapterUtil::StartIpPhoneSearch: This PC has 2 network cards...
16:16:36 1 CNetAdapterUtil::StartIpPhoneSearch: ignore VPN or Virtual adapter with index 0!
And because of these errors, i can't see the video, only can hear audio.
Cheers,
Hunt
Re: CUVA error
Watch out for CSCsl08616 If 2 ethernet NIC enabled & active- CUVA cannot associate with IP Phone
To prevent this from impacting you make sure to run the latest version 2.2(1.7)
If after that this is still impacting you it may help to provide a bit more info about the versions you are running and a larger debug snippet. Also you may want to consult with this FAQ for the more common issues.
Re: CUVA error
Hi bvanturn,
As per the attached screenshot, the customer is already using the latest version 2.2.1.7.
Cheers,
Hunt
CUVA error
I am having the same issue.  Two network cards active and enabled.  One for my WiFi and one for AnyConnect VPN.
I am running CUVA version 2.2.2.0
Here is part of the debug
11:12:37 2 CCamera::CCamera
11:12:37 2 CCamera::SetCameraPresent: Detected Integrated Webcam...
11:12:37 2 EyebeamWrapper::OnCameraChange: Recreating Camera Maps...
11:12:37 2 EyeBeamWrapper::OnCameraInfoList: Adding Integrated Webcam to FriendlyName Camera Map...
11:12:39 2 Discovered IP Communicator: IP=[10.55.1.84] Port=[4224]
11:12:39 2 CMainWindow::OnFoundIpCommunicator: Detected Cisco IP Communicator...
11:12:39 2 CCastClient::CreateCastConnection: IP Communicator: Creating CAST Connection...
11:12:39 2 CCastClient::OnConnect: IP Communicator
11:12:39 1 CCastClient::OnConnect: IP Communicator: Connect to Phone failed with Error-Code 00010013...
11:12:39 2 CCastClient::CloseCastConnection: IP Communicator: Closing CAST Connection...
11:12:39 2 | ======> CVieoApp::OnVideoTransmissionStop
11:12:39 2 | <====== CVieoApp::OnVideoTransmissionStop
11:12:42 2 CCastClient::OnTimer: IP Communicator
11:12:42 2 CNetAdapterUtil::GetCdpMib
11:12:42 2 CNetAdapterUtil::StartIpPhoneSearch: Starting IP Phone Search
11:12:42 2 CNetAdapterUtil::StartIpPhoneSearch: This PC has 4 network cards...
11:12:42 1 CNetAdapterUtil::StartIpPhoneSearch: ignore VPN or Virtual adapter with index 0!
11:12:42 1 CNetAdapterUtil::StartIpPhoneSearch: adapter with index 1 cannot be used because : type is 00000006 operational status is 00000000...
11:12:42 1 CNetAdapterUtil::StartIpPhoneSearch: adapter with index 2 cannot be used because : type is 00000071 operational status is 00000000...
11:12:42 1 CNetAdapterUtil::StartIpPhoneSearch: adapter with index 3 cannot be used because : type is 00000071 operational status is 00000005...
11:12:42 2 CCastClient::OnTimer: IP Phone
640
