cuva support for 7961 phones
Hi ,
A very small query-- is CUVA is supported on CUVA phones. user not able to configure it.. even though it seems everythign configured correctly.
Abhishek
Would really appreciate a response on this.
Whatever level you reach getting better never stops -- Sachin Tendulkar
1 REPLY
Hall of Fame Super Red
Hi Abhishek,
Supported Cisco Unified IP Phones
Cisco Unified Video Advantage is supported on Cisco IP Communicator and on all video-enabled Cisco Unified IP Phones running the SCCP and SIP protocols. The phone must be CDP and CAST capable. The computer running Cisco Unified Video Advantage must be connected by ethernet to the supported Cisco Unified IP Phone.
Cisco Unified Video Advantage also supports Cisco Unified Personal Communicator running in deskphone mode.
The following phones are supported for use with Cisco Unified Video Advantage:
Cisco Unified IP Phone 9971 (only supports H.264 video codec)
Cisco Unified IP Phone 9951 (only supports H.264 video codec)
Cisco Unified IP Phone 8961 (only supports H.264 video codec)
Cisco Unified IP Phone 7911G
Cisco Unified IP Phone 7940G
Cisco Unified IP Phone 7941G
Cisco Unified IP Phone 7941GE
Cisco Unified IP Phone 7942G
Cisco Unified IP Phone 7945G
Cisco Unified IP Phone 7960G
Cisco Unified IP Phone 7961G
Cisco Unified IP Phone 7961GE
Cisco Unified IP Phone 7962G
Cisco Unified IP Phone 7965G
Cisco Unified IP Phone 7970G
Cisco Unified IP Phone 7971 G
Cisco Unified IP Phone 7971 GE
Cisco Unified IP Phone 7975G
Cisco Unified IP Phone 6921 (SIP only supports H.264 video codec. SCCP supports H.263 and H.264 video codecs.)
Cisco Unified IP Phone 6941 (SIP only supports H.264 video codec. SCCP supports H.263 and H.264 video codecs.).
Cisco Unified IP Phone 6961 (SIP only supports H.264 video codec. SCCP supports H.263 and H.264 video codecs.)
Note Cisco Unified IP Phone 9971, 9951, 8961, 6921, 6941, 6961 require Phone Firmware 9.1.1. This is supported on Cisco Unified Communication Manager 7.1.3 or higher.
http://www.cisco.com/en/US/docs/video/cuva/2_2/english/release/notes/relnote_cuva22.html#wp1078995
Cheers!
Rob
582
