CUVA with Cisco IP Phone & CUCME
Hi all,
I have a small problem. Recently I setup CUVA (2.1.1) for testing with our CUCME (8.6) and couple IP phones (Cisco 7960G running newest firmware & SCCP). When I run CUVA with IP communicator everything is working fine (video, audio etc) is working. When I connect my PC to the back of the phone and I want to use CUVA with an IP phone my CUVA can't detect IP phone. There is no ACL on my router. I can access phone build in http website, I can see traffic is going through phone switch but for some reason I can't get it to work. Any ideas?
Reagrds,
Pawel
  • IP Telephony
Blue
Hi Pawel,
What is the OS of the PC. We do not support OS like Win 7.
Ronak Patel
Rate hellpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Yes it is Windows 7. Are you planning to support Windows 7 in future?
Blue
I  dont think so it will be supported. Windows 7 will be certified for the  next generation of CSF-based video clients (CUCI-MOC, CUCI-Connect, and  CUPC 8.x)
If  you are certifed partner, You can raise cisco PDI case to get the  roadmap information. To open case at PDI go to cisco.com/go/pdihelpdesk.  It is free service.
Ronak patel
Please rate all helpful post by clicking stars below the answer.
Ok so it's not supported by Cisco but did anyone else managed to find solution for this problem?
145
