CUWL license issue on cucm 9.1
Dear All
we have cucm 9.1 and I have CUWL Professional license . we are also using unity connection 9.1 as well.
the issue is when i add a mail box for my user the system will go in "Insufficient license" and count in to "basic messaging = -1"
this is against the documents, because they mention clearly that CUWL Professional include unity connection license
so can any one help please?
I am using ELM and i added cucm and unity as instance into ELM
regards
VIP Purple
Hi Kathy,
Can u share the snapshot of error message?
If possible, share the License usage from ELM
regds,
aman
Guys,I am facing the same
Guys,
I am facing the same problem.
Can any body share its solution please ?
VIP Super Bronze
The most common mistake here is that CXN will register to it's local co-res ELM instance at install time. You need to associate the product instance with whichever ELM instance you have uploaded your license file to. It's far more common for this to be co-res with CUCM or standalone.
Please remember to rate helpful responses and identify helpful or correct answers.
Hi Kathy,How did you fix your
Hi Kathy,
How did you fix your problem ?
I am facing the same issue & need help.
345
