CUWL Std - Generate Unity Connection License file
We have CUCM 8.x cluster & Unity Connection 8.6 cluster.Recently we purchased 300 CUWL standard license covering both CUCM and CUC . I used the provided PAK(along with CUCM server MAC) to generate CUCM license. Now how can I use the same PAK to generate Unity Connection voicemail box license as the 300 CUWL Standard we purchased covers for both the systems?
I tried using the same PAK on Cisco site but got error saying the PAK is already used..
KMS
VIP Purple
How u have received the licenses [Electronic form or physical delivery]?Please cross-check once more whetheru have received more than one PAK Key.
Same PAK cannot be used, as the message is coming while u are trying to do so.
regds,
aman
Hall of Fame Super Silver
You should have received separate voicemail user PAK wit purchase of CUWL, look for those and register with UCXN MAC and apply to UCXN Publisher.
HTH,
Chris
378
