Désactivate SRST Registration for some Analog Port on a Voice Gateway
Have you an idea who to turn off SRST registration for only some Analog ports on a Cisco Voice Gateway 224 using SCCP.
Best Regards
Nizar HOUICHI
Hall of Fame Super Silver
Configure the devices in CUCM with new device pool that does not have SRST reference assigned, also you can remove dial-peers pointing to the port, i.e.
dial-peer voice 100 pots
service stcapp
port 2/0
HTH,
Chris
Thank you for your fast reply, But removing the dial-peer does not affect normal function widh CUCM?
It does, my apologies, simply do the first portion.
HTH,
chris
Thank you for your reply. I will test it and i will give you an update.
The issue that I'm not using SCCP auto configuration or tftp download configuration, I have to do manually all configuration on the VG using CLI.
Best Regards
Nizar HOUICHI
Does not matter, you still assign DP to the device in CUCM in one way or another, so simply ensure the DP assigned to these devices does not have SRST reference defined.
HTH,
Chris
274
