dail-peer not working
Dial peer 14 is not working:
http://pastebin.ca/1281736
debug voice dialpeer inout:
Dec 10 16:30:47.846: //-1/BC172FC2B698/DPM/dpAssociateIncomingPeerCore:
Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=103
Dec 10 16:30:47.850: //-1/BC172FC2B698/DPM/dpMatchPeersCore:
Calling Number=, Called Number=2142346837, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=2142346837
No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
Dec 10 16:30:47.850: //-1/BC172FC2B698/DPM/dpMatchPeersMoreArg:
Result=NO_MATCH(-1)
1 ACCEPTED SOLUTION
Re: dail-peer not working
Hi Shaun, when you show dial-peer voice summary, what is the status of the dial-peer 114? Up or Down?
What I have noticed is that the trunk group label that you have assigned does not have any active voice-ports. Therefore I suspect that it is down.
Should the trunkgroup label be 'trunkgroup Local' and NOT 'trunkgroup local'?
Hope this helps
Allan.
Hope this helps
Allan.
Im an idiot, thanks for your help.
local should have been Local. It is case sensitive.
You were right.
123
