dail-peer voice down
when i show dial-peer voice summary in voice gateway (where defined srst), i found 50/0/1 ~ 400 are down. how can i reset these ports and make it up again?
1 REPLY
Re: dail-peer voice down
These are dial peers that are created for the ephones that register in SRST mode - the ephones are considered as POTS dial peers and start from virtual voice port 50/0/1 upwards.
Unless the router is in SRST and the phones registered, these dial peers will normally show as down.
101
