dail-peer with MGCP
hi guys ,
do i need to configure the dial peer for voice ports or endpoint on the router if im using MGCP or it will be created automatically when the router download config from the CCM? . by the way i have not seen dail- peer after successfull config download on running config. for E1 ISDN, FXO , FXS
Re: dail-peer with MGCP
do you have configured the ccm-manager config server??
if not that's why the config is not being sent
if not, you can configure them manually adding the application mgcpapp for those dial-peers
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
well yes i configured the ccm-manager config server and already downloaded the config and the gateway registred and the endpoint as well. but i dont see dail-peer configurtion. why do i need dial-peer in mgcp? ALREADY UNDER VOICE PORTS APPLICATION Mgcp. IS THERE DIFFERRENCE CONIFG FOR DIAL-PEER BETWEEN ANALOG fxO AND e1 isdn
the basic difference is the port to which you refer when configuring the dial peer
javalenc
java
116
