Daily call records from CUCM (7.1.3)
Hi All,
Help in this area would be much appreciated.
I have been asked to produce a daily report on the following:
Calls made / received to an extension
Call duration
Digits dialled
(and so on)
Thank you in advance
Hi Paul,
             Follow the links below. it should give you the necessary information to set it.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/7_1_2/car/carcdru.html
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/7_1_2/car/caruseru.html
Abdul
Hall of Fame Super Silver
Paul,
For more rebust call accounting reports you may want to explore 3rd party solutions, such as ISI, eCAS, and many others as the built in CMR has not changed since version 3.3 and is indaquate for customers requiring any reporting other than simple search.
HTH,
Chris
We had a similar issue.  Basically, we dump the CDR data every hour.  Pull the data into SQL and then create reports.  I don't think it was easy but now that its in place we have a template.
309
