Data and voice on same interface
Hi there,
My customer doesn't want to use subinterfaces or multiple interfaces (Data and Vice) on the Gateway, he is configuring the subinterfaces on the router.
The remote site ip phones registers correctly. But the SRST test failed.
The config is as follow:
ip dhcp pool DATA_GNG_02
network 10.20.26.192 255.255.255.192
default-router 10.20.26.253
dns-server 10.20.1.17 10.20.1.19
ip dhcp pool VOICE_GNG_02
network 10.20.26.128 255.255.255.192
default-router 10.20.26.129
option 150 ip 10.20.149.34
interface GigabitEthernet0/0
description Liaison Vers LAN Gounghin
ip address 10.20.26.1 255.255.255.192
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.20.26.1
call-manager-fallback
max-conferences 8 gain -6
transfer-system full-consult
ip source-address 10.20.26.1 port 2000
max-ephones 58
max-dn 116
system message primary Systeme de Secours Actif
transfer-pattern ....
no huntstop
date-format dd-mm-yy
Can i keep the same interface for data and voice? or should i configure a loopback interface for example?
Hi Youssef,
I dont see the subinterface configured in this configuration. What IP addresses are the phones getting since the subinterface is missing?
Please rate useful posts.
Sorry i mean that the customer is configuring the subinterfaces on the firewall not on the router
Thanks in advance.
Can you put your PC in the voice vlan and see if you can ping the address 10.20.26.1. Has this address been added under the SRST Reference/device pool?
I have done this exact test and i can ping 10.20.26.1 from the voice vlan , the gw and srst reference has this same ip address.
Is this a ISR G2 router? Has the EULA been accepted?
This is a Cisco 3925 with IPvoice license, and yes, i have already accepted the EULA.
Thanks George
The only thing I can think off is the firewall is doing some kind of inspections on TFTP/SCCP (since voice traffic needs to route through the firewall to get to this router) traffic which is causing the issue. I guess you will have to see if someone else has some other ideas.
It would be ideal if you could move the subinterface to this router to rule out that issue.
Thank you george for your support,
We have disabled the Sccp inspection on the Juniper Firewall because it was causing registration issues. But now the problem with SRST is that the phones (Cisco 7942) registers to the gateway but no ephone dn is assigned to it. When we remove the firewall and use subinterfaces on the gw all works fine.
That to me sounds like the firewall is doing something. I would turn off TFTP inspection as well and see if that makes a difference.
I am pretty sure that the security guy has already disabled the tftp inspection, now back to the main question : Can i use the same GigabitEthernet0/0 for data and voice?
Yes, you can keep same interface for data and voice. Best practice is loopback but that varies depending on environments.
178
