Silver
data communication error cucm
I have a single CUCM7.X server running in VM however I getting communication error when I try to log in . The web search I`ve seen are for for a Pub, Sub situation so does not seem to apply to this set up . The database "A Cisco DB" is stopped and can not restart it- any ideas ?
thanks
Community Member
Re: data communication error cucm
Do you have DNS enabled? (You can check by using: show network ethernet0 details)
If it's enabled, try to disable DNS from CLI. I'll get you the commands in a next reply.
Another possible cause of the problem, did you change the IP of the call manager?
Silver
Thanks, I will check the DNS. the IP has not been changed - that I know
375
