Data Migration assistant Consolidated error log/warning log
just ran DMA 5.1.3 before upgrading CCM from 4.1.3 to 5.1.3
How are the errors reported in the Consolidated error and warning logs fixed
is there any doco available to assist
with fixing these SQL and LDAP errors?( which seem to be the majority of the errors)
Green
Re: Data Migration assistant Consolidated error log/warning log
You can open a TAC case or upload the DMA log files to see if those errors are easy to fix from here, otherwise you may need someone from our side to access remotly.
sorry for delay been away.
please find enclosed logs
115
