Si
Data network for VoIP traffic
Currently work on multiple LANs designed for data. 6509 cores linked together using L2 POs. All HSRP/ OSPF Adj are via these links.
Ive recenly read ideally VoIP needs L3 connectivity between cores, and distribution layer. L3 dist is a non starter but would it be better design to add L3 Port channels also between cores? If i didnt, what negative problems could occur?
Many thanks
S
Hall of Fame Super Silver
L2 or L3 is fine, L3 eliminates convergence with STP hence the recommendation.
HTH,
Chris
Si
Thanks Chris, thats good to know. I asked the same on the Learning network and was advised L3 from the Distribution
L3 is prefered, L2 is fine.
HTH, please mark the question as answered unless you have further questions.
Chris
Si
Thanks Chris, final question. Im hoping to use class c vlans for voip. Would having the vlan scattered around the lan cause problems?
We are deploying 48 port POE around campus and configuring ports based on how many address are free in that subnet, then rolling onto the next subnet if full.
S
152
