Database communication error when accessing cucm through GUI
Dears
When i try to access my call manager 8.5 through GUI
after entering the username and password
on the left corner it gives me "Database communication error "
Any Idea
Thanks in advnace
VIP Purple
Hi Zaher,
there is a problem with Database replication among servers in a cluster.
can you share output of command utils dbreplication runtimestate from publisher or from cisco unified reporting , u can check Database status [should be ideally GOOD]?
you can also refer the DOC
https://supportforums.cisco.com/docs/DOC-13672
regds,
aman
Hi Aman
it's working now
in order to fix it, must reset the dbreplication
Thank you
286
