Database Communication Error
aHello I have not access CUCM I get this messaje Database Communication Error
admin:
admin:utils dbreplication status
-------------------- utils dbreplication status --------------------
Fri Jun 25 10:45:23 CDT 2010:main:General SQL failure:
Fri Jun 25 10:45:23 CDT 2010:main:java.sql.SQLException: Failed to get Connection.Connector(NOT CONNECTED: Driver=com.informix.jdbc.IfxDriver;)
        at com.cisco.ccm.dbl.Connector.getConn(Connector.java:698)
        at com.cisco.ccm.dbl.Connector.connect(Connector.java:588)
        at com.cisco.ccm.dbl.Connector.connect(Connector.java:530)
        at com.cisco.ccm.dbl.Connector.createStatement(Connector.java:757)
        at com.cisco.ccm.dbl.Connector.createStatement(Connector.java:744)
        at com.cisco.ccm.dbl.Connector.executeQuery(Connector.java:921)
        at com.cisco.ccm.dbl.idbl.executeSelect(idbl.java:672)
        at com.cisco.ccm.dbl.idbl.executeSQL(idbl.java:1251)
        at com.cisco.ccm.dbl.idbl.run(idbl.java:1404)
        at com.cisco.ccm.dbl.idbl.main(idbl.java:1470)
Status cannot be performed when replication is down on the publisher, or on a cluster with a single active node; aborting replication status check operation
Output is in file cm/trace/dbl/sdi/ReplicationStatus.2010_06_25_10_44_02.out
admin:
anyone can help me?
792
