Community Member
Database log truncated error message in CallManager EventViewer
I have Call Manager 4.1(3) with BARS 4.0.6000. CM tunes for making backup every night and every time I see two error messages in EventViewer:
Event Type: Error
Event Source: MSSQLSERVER
Event Category: (6)
Event ID: 17055
Date: 4/15/2007
Time: 2:00:25 AM
User: ELVARY-CCMP\BackAdmin
Computer: ELVARY-CCMP
Description:
18278 :
Database log truncated: Database: CDR.
Data:
0000: 66 47 00 00 10 00 00 00 fG......
0008: 0c 00 00 00 45 00 4c 00 ....E.L.
0010: 56 00 41 00 52 00 59 00 V.A.R.Y.
0018: 2d 00 43 00 43 00 4d 00 -.C.C.M.
0020: 50 00 00 00 04 00 00 00 P.......
0028: 43 00 44 00 52 00 00 00 C.D.R...
and
Event Type: Error
Event Category: (6)
Event ID: 17055
Date: 4/15/2007
Time: 2:00:07 AM
Description:
18278 :
Database log truncated: Database: Ccm0300.
Data:
0020: 50 00 00 00 08 00 00 00 P.......
0028: 43 00 43 00 4d 00 30 00 C.C.M.0.
0030: 33 00 30 00 30 00 00 00 3.0.0...
At the same time backup files is create.
Does anyone know what do the errors mean? Can they lead restore process to fail?
1 ACCEPTED SOLUTION
Re: Database log truncated error message in CallManager EventVie
The event that you see in the App log is not a problem. It is telling you the SQL backup
has completed and as such the transactional logs are not needed and so are deleted. This
is so because if we keep the transactional logs the size of the Database will increase
causing disk space shortage and hence we will have issues with services stopping.
MCS BackupUtility by default " deletes " the transactional [ ART / CDR ] logs after a
backup. When this is done you will see the error you mention. This is nothing to worry
about. MCSBackup basically reduces/removes unnecessary data to be backed up, grab a copy
of the database, and backup this copy to the stream file. I think it would be better that
message type is changed from Error to Information by Microsoft.
Microsoft has already announced this issue :
http://support.microsoft.com/default.aspx?scid=kb;en-us;818202
Upon research, I also found that this error is basically due to two different Bugs in
Microsoft. Here is the link which gives us more information on this :
http://proxify.com/p/000010A/http/support.microsoft.com/default.aspx?scid=kb;en-us;308267
So again in short nothing to worry about - just informational message that the
transactional logs have been truncated [ deleted ]. Do let me know if I could be of
further help or if I could proceed with closure of this SR. Thank you and you have a nice
day ahead.
Community Member
It's a normal occurrence as part of the SQL backup procedure and can be safely ignored.
day ahead.
524
