Date and time of IP phone configured in CUCM
I am using CUCM 7.1.3 and I have few questions. Can someone please help me?
1) Is it possible to find out when the phone (device/line) is actually configured in CUCM?
2) Can we pull the information when the phone is registered for the first time and subsequently any logs when the phone was down/up, etc?
Mady
  • IP Telephony
1 REPLY
Re: Date and time of IP phone configured in CUCM
1) you should be able to find out with the audit logs, time constrain from below also applies.
2) app logs and traces will have this info, but there's not going to be a "this is the 1st time this phone registers" message. They'll look exactly the same as if it was the 100th time it registers. Also, since this logs are nor permanently kept in CUCM, it all depends on how much info is stored whether you'll be able to find this for all phones or not.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
134
