04-17-2012 01:16 PM - edited 03-16-2019 10:41 AM
Dear Experts,
I work for a Global University IP Telephony(CUCM v8.5) Team and the site has one publisher and two subscribers hosted on a Virtual Environment(Vmware-UCS) in a single Server. An unplanned power outage has caused the publisher subscriber DB replication issue. I did the following but in vain.
1. "utils dbreplication stop" on both the subsribers
2. "utils dbreplication stop" on the publisher
3. "utils dbreplication reset all" on the publisher
And it did not help resolve the problem. After that I also tried doing the "utils dbreplication repair" on the publisher with no change in the db replication.
I do see some posts where the mention about rebooting the publisher and subscriber. If that be the case please do mention the difference between rebooting and restarting via CLI.
Please help me and I sincerely thanks for all your help.
THANKS, Saravanan
04-17-2012 01:27 PM
I am also finding that any incorrect NTP settings would cause DB replication. I did see some NTP warnings/critical in the RTMT until few days ago but essentially they are gone in the last two days but the db replication problem still persists. When I checked NTP Server settings I did find the publisher IP is mentioned as the NTP server. I just wanted to add this additional information. Thank you !
04-17-2012 05:43 PM
What do you replication states currently show as "utils dbreplication runtimestate"? If the UCS lost power and shutdown you might want to check for file system corruption by running the recovery disk on each server and checking for errors. I'm not sure if the UCS has a write-cache battery to help prevent file system issues in the event of a power loss. There's also a documentation bug to note that a rebuild should be done if you find errors when running the recovery disk CSCth53322.
04-18-2012 01:53 AM
Dear Joe, Please find the attached CM database Report that from the Publisher.
04-18-2012 01:57 AM
Could see one server 10.112.5.11 is down.That's the reason you end up seeing bad replication across the cluster.
Is it down due to maintanence ?
Siva
04-18-2012 02:43 AM
Hi Siva,
I am able to ping the subscriber 10.112.5.11 from the pub 10.112.5.10 and vice versa. Pls find the db replication status from both the pub and sub1.
DB Replication Status from the Publisher
admin:utils dbreplication runtimestate
DB and Replication Services: ALL RUNNING
Cluster Replication State: Replication status command started at: 2012-04-17-17-19
Replication status command COMPLETED 530 tables checked out of 530
No Errors or Mismatches found.
Use 'file view activelog cm/trace/dbl/sdi/ReplicationStatus.2012_04_17_17_19_11.out' to see the details
DB Version: ccm8_5_1_10000_26
Number of replicated tables: 530
Cluster Detailed View from PUB (6 Servers):
PING REPLICATION REPL. DBver& REPL. REPLICATION SETUP
SERVER-NAME IP ADDRESS (msec) RPC? STATUS QUEUE TABLES LOOP? (RTMT) & details
cm-pub 10.112.5.10 0.025 Yes Connected 0 match Yes (3) PUB Setup Completed
cm-sub2 10.112.6.10 0.273 Yes Connected 0 match Yes (3) Setup Completed
cm-sub1 10.112.5.11 0.147 Yes Off-Line N/A DB-diff No (3) Not Setup
cm-sub3 10.112.5.12 0.118 Yes Connected 0 match Yes (3) Setup Completed
cm-tftp1 10.112.6.15 0.323 Yes Connected 0 match Yes (3) Setup Completed
cm-sub4 10.112.6.11 0.249 Yes Connected 0 match Yes (3) Setup Completed
DB Replication Status from the Subscriber
Cluster Replication State: Only available on the PUB
DB Version: ccm8_0_2_40000_1
Number of replicated tables: 519
Cluster Detailed View from SUB (6 Servers):
cm-pub 10.112.5.10 4.31 Yes Active-Failed 410358 DB-diff N/A (3)
cm-sub2 10.112.6.10 0.274 Yes Active-Failed 403818 DB-diff N/A (3)
cm-sub1 10.112.5.11 0.025 Yes Connected 0 match N/A (3)
cm-sub3 10.112.5.12 0.145 Yes Active-Failed 403818 DB-diff N/A (3)
cm-sub4 10.112.6.11 0.308 Yes Active-Failed 403690 DB-diff N/A (3)
cm-tftp1 10.112.6.15 0.289 Yes Active-Failed 403818 DB-diff N/A (3)
04-18-2012 03:05 AM
Also the output of the command "utils dbreplication status" from the Publisher:
admin:file view activelog cm/trace/dbl/sdi/ReplicationStatus.2012_04_18_10_59_42.out
SERVER ID STATE STATUS QUEUE CONNECTION CHANGED
g_cm_pub_ccm8_5_1_10000_26 2 Active Local 0
g_cm_sub2_ccm8_5_1_10000_26 3 Active Connected 0 Apr 17 16:22:50
g_cm_sub3_ccm8_5_1_10000_26 5 Active Connected 0 Apr 17 16:22:18
g_cm_sub4_ccm8_5_1_10000_26 7 Active Connected 0 Apr 17 16:24:57
g_cm_tftp1_ccm8_5_1_10000_26 6 Active Connected 0 Apr 17 16:21:57
end of the file reached
I am not able to subscriber 1 at all... You can see sub1 is missing.
Thank you all.
04-18-2012 07:06 AM
From your logs, could see
Here we have to see many factors liks rhost,sql,connectivity,hosts,etc.May i request you to open a TAC case to troubleshoot the issue.
Siva
