VIP Purple
DBHELPER file
Hi ,
I need a DBHELPER.EXE file to check the database replication status in Call Manager version 4.1 .How can I get this file?
regds,
aman
1 ACCEPTED SOLUTION
Re: DBHELPER file
Not sure how you cannot find the file!
If you search for dblhelper you get trillions of hits on the subject and plenty of them have the file, just look at this one:
DBLHELPER file for CCM 4.1(3)
https://supportforums.cisco.com/message/1110345#1110345
It's the 7th hit if you try to search for DBLHELPER in NetPro, the name says it all.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Bronze
Re: DBHELPER file
Hi, this file is located in the c:\program files\cisco\bin directory.
hth
David
Hall of Fame Super Red
Re: DBHELPER file
Hey Aman,
Just to add a note to the help from my friend David (+5 points bud:)
This is just in case
https://supportforums.cisco.com/message/1072190#1072190
Cheers!
Rob
VIP Purple
Re: DBHELPER file
I had already searched the file as specified by you in the path in Publisher but could not find. That is the reason, I posted a message in NetPro.
If u could provide me the file ,it would be great.
regds,
aman
Re: DBHELPER file
The file is already in a lot of older posts, just use the search box and type dblhelper to find it.
Speaking of which, PLEASE SEARCH NETPRO FOR ANSWERS before posting.
java
java
VIP Purple
Re: DBHELPER file
Hi Java ,
I have been unable to locate this file in earlier discussions.Also,I have tried searching in three more CCMs but did not find. Can u please provide this file else I need to open a TAC case/
regds,
aman
Re: DBHELPER file
java
java
VIP Purple
Re: DBHELPER file
Hi Java,
Thanks in tons.
regds,
aman
Re: DBHELPER file
I have executed the DBHelper on publisher. We have a cluster of 4 CCM version 4.2(3). In the status of 2 subs shows  "All jobs are waiting to start". Is this normal behavior? All the servers are shown in green. We are facing multiple issues like phones are registering every now and then, phone are loosing there personalized settings like ringtones and we ARE able to add the duplicate mac-address of phones.
saif
1281
