dbhelper to fix broken sql replication
trying to fix broken sql replication. republish popup window displays
"republish must be run in the directory with replication scripts. this is usually c:\programs\cisco\bin" Is it possible DBHelper was installed to the wrong location? thanks
Re: dbhelper to fix broken sql replication
could be, make sure the actual dblhelper file is on the folder mentioned by the error
java
if this helps, please rate
java
www.cisco.com/go/pdi
Hi!
Remember you can only run the DBLhelper tool in the publisher server and as he said, it must be installed under:
C:\Program Files\Cisco\Bin
Also, these links might help, the first one talks about using DBLhelper and the second one can be used when the subscription needs to be fixed (recreated) manually.
*** Using DBLHelper to Reestablish a Broken Cisco CallManager Cluster SQL Subscription ***
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00801e7ddf.shtml
*** Reestablishing a Broken CallManager Cluster SQL Subscription with Cisco CallManager ***
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00801d11a6.shtml
Have a nice day!
Teresa.
Regards, Tere. If you find this post helpful, please rate! :)
thank you all for your posts
As a follow up question, am i correct in my thinking that a broken sql replication could contribute to cdr records not working?
depends, were they working before??
most usually CDRs not working might be caused by passwords out of sync or misconfiguration
java
java
Yes, a broken SQL replication can break CDR too. If it was working before and replication failed, the CDR data will not be uploaded to the ART/CDR Database, therefore the CDR reports can fail. Probably you'll see only past records and not the recent ones.
Tere.
566
