Bronze
DBLHELPER file for CCM 4.1(3)
Hi dear cisco forum, I have CCM 4.1(3)sr5d servers installed (Publisher and Subscriber) but the DBLHELPER files to reestablish a broken SQL subscription is missed in this version. It is neccesary to open a TAC case in order to obtain this file?. Or, it could work too if someone in the forum would send or add this file to make it work.
Thank a lot friends
David
VIP Super Bronze
Re: DBLHELPER file for CCM 4.1(3)
Ensure that you are running the dblHelper from this folder:
c://programfiles/cisco/bin...
If you are not, copy it to this folder and run it again..
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Bronze
Thanks for your reply. I search this file but in my CCM Publisher, but I can't find it.
Is it necessary to open a TAC case to obtain this file?.
Thanks a lot boys
David
VIP Super Bronze
Ok. So you do not have the DBLHelper tool.
It does not come with callmanager, you need to obtain it from TAC.
I have attached it here for you
Bronze
Thank you very much for your help and the file my friend, just one nmore question, Is this file compatible with my CCM 4.1(3)?.
David
VIP Super Bronze
Yes,
I am using CCM 4.1(3)sr5b
So it is..
Please rate the post if it helps you
Bronze
Thank a lot my friend, I'm going to reestablish the broken connection in a few minutes.
Thanks, thanks.
David
885
