DBLHelper for CallManager 5.1
Hi All,
Does anybody know if we have any tool for CallManager 5.0 (5.1) to check database re-alignment like DBLHelper??? How are we supposed to work with database on Linux CCM?
Thanks!
mchandak
Level 7
Level 7
From the CLI, you can use the option "utils dbreplication status". There is no DBLHelper available for CallManager 5.x. This feature has been added to the above CLI command
Thanks a lot for the answer! What should I do if the "status" shown is not healthy?
Regards.
I'd recommend using "utils dbreplication repair all" and incase this does not fix the issue, please open a TAC case as there were a few bugs which have been fixed with the latest ES for CM 5.0.4 and 5.1.1
Thanks a lot!
