DBLHelper for CallManager 5.1
Hi All,
Does anybody know if we have any tool for CallManager 5.0 (5.1) to check database re-alignment like DBLHelper??? How are we supposed to work with database on Linux CCM?
Thanks!
Gold
Re: DBLHelper for CallManager 5.1
From the CLI, you can use the option "utils dbreplication status". There is no DBLHelper available for CallManager 5.x. This feature has been added to the above CLI command
Thanks a lot for the answer! What should I do if the "status" shown is not healthy?
Regards.
Gold
I'd recommend using "utils dbreplication repair all" and incase this does not fix the issue, please open a TAC case as there were a few bugs which have been fixed with the latest ES for CM 5.0.4 and 5.1.1
Thanks a lot!
145
