12-05-2006 10:38 AM - edited 03-14-2019 07:05 PM
I get this error when going through the route patterns click on the edit by the route list and clicking on the route group, click on the gateway and click on the FXO interface.
DBLX.AnalogAccessPortListX.1
error '80040615
CDBLException Dump: [ActiveX object not initialized via insert or select]
/ccmadmin/mgcpsidemmenu.asp, line 272
slot0/ sub-Unit 0
Going through the gateway configuration page this error does not come up.
Any ideas?
Solved! Go to Solution.
12-05-2006 02:19 PM
We had a similar problem last month and after a reboot of the whole cluster or
removing the configuration for the FXO and restarting the router fixed the issue
Its related to...CSCsf31842
Symptom:
When clicking the fxo ports attached to the route group, we get error
DBLX.AnalogAccessPortListX.1 error '80040615'
/CCMAdmin/mgcpsidemenu.asp, line 252
Conditions:
Modified route pattern and then deleted rp, rl and rg
Workaround:
Restart ccm and rebooted callmanager
12-05-2006 02:19 PM
Symptom:
Conditions:
Workaround:
