Community Member
DC Directory login
What is the username to login to DC Directory Admin? DCDAdmin is not working...
thanks
Gold
Re: DC Directory login
I think that the user is 'Directory Manager'.
Hope this helps,
Juan Luis
Yes, the username is Directory Manager, and the password is encrypted on the DirectoryConfiguration.ini that is on C:\dcdsrvc
By default the password is ciscocisco, but if that does not work then go to that file and send me the encrypted password, I will decrypt it and send you the one that you are using.
http://www.cisco.com/warp/customer/788/AVVID/dc_directory_password.html
//J
Community Member
J
can you decrypt my DC ini password, or tell me how to
it is
passwd=xxx
-Paul
Decrypted password is: Snak33yes
It is case sensitive.
Community Member
Now for my lab cm. passwd=07111c052211
Thanks in advance.
Community Member
Disregrard, I figured it out.
Thanks anyway
Community Member
97c072924fc50ee518f2f130dfc7059922c97216
154
