DDI Fax lines
Can I have two DDI's ( that are fax lines) terminating on the one extension number?
1 REPLY
Super Bronze
Re: DDI Fax lines
Certainly - usually you would have one directory number on the Fax (use the one it should display for outbound CLI), and then create a translation pattern to map the other DDI to that directory number.
Aaron
Please rate helpful posts..
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
155
